Russ Karnap
RV-7A
Left Wing - Drilled Z Brackets to Baffle
Drilled all 7 Z Brackets to the Baffle on the Left Wing. Used #30 bit for center holes (accidentally), then a 1/8" bit for all the other holes.
Tried to cleco on the Fuel Tank Skin to the Ribs, but it was too tight.
Z Brackets on Baffle
Trying to Cleco the Tank Skin
Z Bracket first 1/8" Hole on Baffle side
RV-7A Home
776
EAA Tech Counselor R
Emp: Elevators
Emp: Horizontal Stab
Emp: Rudder
Emp: Vertical Stabil
Empennage: General
Primer
Primer/Paint Prep
468
