Russ Karnap
Date:  2-8-2018
Number of Hours:  7.00
Manual Reference:  6: Empennage
Brief Description:  Continued Elevators
Match drilled counterweights and all skeleton parts for both left and right Elevators. The hole on the Right CW Rib is really close to the web. Will need to trim one side of washer to fit. But the other three match drilled holes are nearly centered in their respective ribs.
Bent the trailing edge with my 2"x8" x 5' brake. Worked well, but couldn't get the last couple of degrees since the stiffeners touched each other inside. Going to try to move the skin away from the hinges to try to just squeeze the last couple of inches of the skins. We'll see how it works out...
Fluted and straightened the ribs for both Elevators.
Match drilled Right Skin to Right Elevator Skeleton. Disassembled. Ready for prep and prime.
