Russ Karnap
Date:  1-16-2018
Number of Hours:  4.00
Manual Reference:  6: Empennage
Brief Description:  Primed HS and VS
Primed all remaining HS and VS parts with Akzo. Still only using Degreaser and Acetone with maroon Scotchbrite to prep parts. Some parts have not been dimpled yet. Curious to see how it dimples after priming.... Stay tuned.
MISC:
Received portable air con for shop. Cut holes in outside door to vent the dual vents. It trips the breaker if it is on when the air compressor turns on... Need a different circuit. This one is only 15amps.
Received temp/humidity sensor. Will try to record values when priming/painting.
Temp: 75 F
Humidiy: 60%
