Brief Description: Skybolt flanges and wheel cotter pins
Bent the skybolt flanges downward using the handseamer and got the cowling to fit closer. Still not happy with it but I will have Daddy take a look at it to verify that my thinking by bending them down is correct. Installed the correct cotter pins in both of the wheel axles and torqued the rear spar attach bolts to 125 inch pounds as required. Did not safety the bolts because I could not find the correct cotter pin. I did flag the bolts with pink tape to remind me though.
