Bolted the prop extension and flywheel onto the front of the crankshaft. Used Loctite on the bolts as called for and torqued them to the proper 45 ft. lbs. Fixed the floor in the backseat so that it will fit around the 5th point attach bracket for the seat belt. Riveted a stiffener in place so that the floor would remain stiff in this area. Began trimming the lenses to fit the lights on the end of the wingtips.
