Continued the electrical wiring work. Most of the work centered around wiring the alternator system up. Cleaned up wiring around the engine using zip ties, installed the correct mag harness on the right mag and secured the harness to the spark plugs. Ran a cooling tube from the rear of the baffle to the gascolator. Installed the oil cooler and tightened all of the oil fittings on the engine.
