With Phillip's help installed the prop. Torqued all of the bolts to 17 ft/lbs and safetied them using .041 safety wire. Installed all of the spark plugs with the correct crush washers and anti-seize. Began hooking up the carb and throttle cables at the carb but discovered I'm missing a bushing to go in the carb arm. Temp. hung the hardware on there so I wouldn't lose it. Installed the ELT in the forward compartment using the included mounting plate. Looks good! Put together the vent and bracket I fabricated yesterday and installed it. Installed the door in the rear seat air vent as well.
