Took a look at the exhaust gaskets. Loosened the mounting bolts and retightened them. Still had the same little gap. It looks like this may be the result of the shape of the exhaust flange and not of them being to loose. Alos rerouted the fuel line from the fuel pump to the carb. to get it away from the exhaust. Screwed it onto the pump first and then the carb, instead of carb first and then pump like I had tried previously. Doing this moved it an acceptable distance from the exhaust now. Still going to use the heat shield just as a precationary kind of thing. Fit rubber baffle strips to the two rear sections of the baffle. Elected to go with a lot of smaller strips versus a few big ones so that the curve vof thre cowling will seal up better. It turned out good.
