Brief Description: Baffle repair and fresh air vent
Fixed the right side of the baffle where the ramp did not meet the lip of the bottom cowiling when it was installed. Drilled out the angle that held it in the wrong position. Fabricated and extension for the side so that the lip could be angled down more and then reinstalled it. The plate should be plenty strong. Took the baffle to the house and primed it. Cut the hole in the right side of the plane and installed a NACA vent for the front seat usign the kit from Vans.
