JOHN LUKE'S WEB SITE
Date:  2-16-2015
Number of Hours:  6.00
Brief Description:  Fuel Lines, baffle painting, oil breather line
Painted the baffles. Used a high temp. engine enamel. Also painted the cylinder heads red using a brake caliper paint. Turned out looking good! Installed the fuel elbow fitting in the carb. and in the gascolator. Changed out the fuel fitting coming out of the fuel pump and installed the "T" fitting that was tapped for the fuel pressure line. Hooked up all of the fuel lines as well as the fuel and oil pressure lines. Removed the teflon tape from the pump fittings and reinstalled them with rector seal. Installed the oil breather line. Used two Adel clamps to secure it the the engine mount. Terminated it over the exhaust. Drilled a pressure relief hole about 8 inches from the end of the tube.
