Brief Description: Cowling cheek fit/misc. engine work
fit the cowling cheeks. Drilled out the Skybolt flanges from the bottom cowling. Fit the cheek to the top cowl and clecoed the cheek to the plane. Squeezed the back of the bottom cowl until it fit the cheeks shape and then retrimmed the bottom cowl to fit the top cowling again. Ended up trimming around a quarter inch off of the bottom to get it to fit but now it fits even better than it did the first time! Also cut a slot in the left side of the fuselage behind the cheek and routed the throttle cables through it. Wil reinforce the area with a plate. Flipped the brake cylinder right side up, looked at mounting the master and starter relays, looked at fuel lines, and determined the location of the gascolator and finished fabricating the mounting bracket
