Removed the bolt that broke off using a left handed drill bit. Installed a new bolt in it’s place. Installed the oil strainer and the fuel pump. Attempted to hang the engine but discovered a fitting will be needed coming out of the fuel drain on the pump in order to clear the firewall.
