Brief Description: Master, key, and engine monitor install
Installed and wired the master and key switch. Began wiring of the engine monitor as well. Finished wiring up the alternator system by installing the voltage reguator as well as fabricating the cables from the alternator to the fuse block and from the alternator to the battery, In order the insta the alternator we ended up having to take the prop back off and get a longer alternator belt. Fixed the baffle screw that broke off in the front right baffle support as well.l
