Pop riveted the rubber strips onto the two rear baffle pieces. Installed these two pieces permenantly using the bolts and lock washers on the screws. It should be on for good now! Started fitting the rubber strips to the front pieces as well. Need to look at how the strips go behind the flywheel.
