Installed and timed the mags with the help of Phillip. Reinstalled the prop extention and the flywheel and torqued all of the bolts to 45 ft-lbs. Daddy installed all of the cylinder head and exhaust gas temperature probes. I installed the oil temp sensor. Mounted the starter and master relays to the firewall. Drilled the front two baffle pieces behind the spinner in place and began to fabricate the angle pieces that hold them in place.
