Finished installing the close tolerance bolts in the spar. The only ones left are the center two on the top which also hold the control column and the fifth point for the seat belt attach. Fabricated and installed the F-4?? Brackets that stabilize the top of he spar. Reinstalled the flap actuator. Changed out all of the old lock-washers on the engine and installed the new ones. Discovered a bolt broke off in a hole. Paused until it can be removed
