Worked on the right horizontal stabiliizer today. Drilled the ribs and clecoed on the skin. I inserted HS00005 and HS-00006 into the inboard end clamped HS-00006 in preperation for marking the rivet holes
This went much faster than the left side. Using the saddles to support the assembly also helped.
