Bent one HS-702 tonight. I'm not sure where 2.5 hours went, but it went! I clamped the HS-702 and a block in the spar channel aligned with and just slighty behind the bend line. I used another block to tap on the opposite side of the spar until I got to 6 degrees. Pretty slow process but it came out oretty good.
