Found a small crack in the sheet metal on a radius of the evavator. Removed the crack by increasing the radius.
Asked Mark to suggest the best way to drill the hinge.
Pilot drilled the holes in the hinge. Noted a slight binding in the operation.
Drilled the safety holes in the hindge. Decided to use cotter pins instead of safety wire to prevent the safety wire from interfearing with the hinge operation.
