One of the wires of the aileron trim tab servo broke in handling. Started from scratch and cut out the previous connections, then re-soldered. Heat shrink tubing placed on each joint. Then placed a large heat shrink tube over all the connections. Used nylon cable ties at each end of the heat shrink tubing to immobilize the connection.
