Brief Description: Attached wiring to servo, drilled holes to full si
Soldered the servo wires to the cable. Drilled hole for wire using the step drill for the first time. I was not very happy with the step drill performance.
Clecoed the entire Aileron together and frilled out the holes from #40 to #30 holes. The trim tab mounting bulkhead somehow shifted causing the holes to be drilled off center, runing the part. Will have to fashion another part or buy a new one. Very disapointing.
