ROBERT'S WEB SITE
Date:  6-24-2018
Number of Hours:  5.00
Brief Description:  Antennas
Drilled out and installed the ADSB antenna, and the Transponder antenna. Cut and installed the connectors on coax cable for the ADSB antenna and installed the ADSB module with antenna connected. Istalled the transponder mount next to the antenna on the left side behind the seat. Made a bus bar for each row of swtihces to connect the ground on them which will be connected to the main ground. Installed the GPS antenna. Cleaned out the metal shaving from the bottom of the fuselage. Cut groves in the switched to accomodate the switch guards in reverse, but might not use them that way. Routed some wires up to the front. Started planning the left avionics tray out. Drille out the hole for the heater, which has to be enlarged some. Got word when the prop will arrive today. Waiting a while for that.
