Sanded down the left wing with 400 grit wet sandpaper. Rinsing it frequently is the key to keeping the buildup off the paper. Sanded a run and the dashes over the fiberglass. The second coat went on well but a third was required over the dashes and after sanding a run. The third patrial coat made everything look very good. I am happy with both wings for now. I bought some cutting compound and some uv protectant wax to make the wings look very shiny and smooth. Will put it on the bottom of the elevator to try it and then, if it goes well I will do the wings. Engine comes Monday so I need to be able to move the wings to the hangar then. No room here. First picture is after second coat.
