First sanded the left wing with the maroon scotchbrite pads, then wiped off with a wet sponge. Changed the water in the bucket and then wiped down the whole wing again. Then I blew off with a compressor and then used the tack rags that came from Stewarts that are supposed to be for water soluable paints. Less wax I guess. Then I hit the wing with a fairly light coat. As light at can be with the pressure I have to run to get undiluted paint to spray right. Had a couple of runs and had some areas where the paint was too thin. I also had areas over the fiberglass that had dashes of no paint. Looks like everything is sticking well though.
