Put the rest of the rib tapes on the bottom of the left wing and then put the second coat of poly brush on the tapes. Started the top of the wing and almost finished except for heat forming and gluing down the trailing edge and the second 4" tape on the leading edge. I also need to heat form and tack down the wing ends. Lots of time with the respirator on.
