Brief Description: LE Closeouts, turtledeck closeouts
Worked on the turtledeck closeout aluminum. Finished all but the install and paint. Worked on the flight controls, getting them tighter and getting rid of the free play. Made the leading edge closeouts and test fit them. Put more gas in the tanks and did another leak test. Found and fixed a few minor leaks in the cabin, but one larger one on the front of the firewall will have to wait. At least it is downstream of the fuel shutoff valve. The wing fittings don't seem to leak so far, that was my biggest worry. Folded the instrument panel down to track down leaks and wiring bugs.
