Cut the front part of the turtle deck window to fit up against the rear spar. Took longer than I thougt going back and forth a bunch to test fit. Took the cowling off again and adjusted the cam locks. Bled the brakes again with Ted's help. Ted also helped me check the alignment of the main landing gear wheels and I talked to John at Kitfox and ordered a one degree shim to bring it in line. We put the tail up on a stand to get ready for more flight control rigging. I installed the aileron control horns with clecos.
