WIred the left landing light and installed the mounting and the light in the wingtip. Worked well, but I will have to adjust the angle. Wired most of the strobe/nav light in the left wing. Installed the wingtip temporarily. Having trouble getting the nutplates to line up with the screws. I hate screws. Wired the pitot tube and connected the pneumatic plumbing. Also installed the magnetometer in the left wingtip. Used my balsa wood and dowel rod mount and secured it with zip ties and wire tie thread. Turned out pretty well and should be easy to remove if I need to. Debating on where I will put the OAT probe. Either in the wingtip or somewere near the wing root. Still not feeling great today so only one pic and a short day.
