Put the Kitfox sticker on the tail, the N numbers on the back sides, the Experimental sticker on the rear spar carry through, and the passenger warning placard on the panel. Got the ADAHRS working and downloaded the high detail terrain. I can see the mountains in Canada in my display and the airport too. Played around with the EFIS display settings some more and have a little more to do. Installed the triangular side windows with adhesive caulk. Cut some wires that I won't be using and heat shrunk the small remainders together in case I decice to use them some day for something else. Worked on the glare shield some more, making the aluminum clips to hold it to the boot cowl and the windshield. Started to make the wiring look a little neater, but I still need to wire the stuff from the wings when they go on. Talked to Bob W. over in his airplane in his hangar from my Com radio. Worked well.
