Talked to Dynon, again, and found out my cht and egt problem was just a sensor setting issue. Fixed it quickly and moved on to other problems. The Rotax EMS is sending bad temp data to the EFIS. I will have to try to sort it out with grounding issues and then call a Rotax service center to get their input. Not a huge issue, but will have to be sorted out. I cut and installed nut plates on the two insturment panel support tubes. Then I cut the cross brace holes and the mounting bracket cutouts in the glare shield. I also cut it to about an inch past the panel to allow for my glare shield lighting strip. Need to rearrange some fuses and then start making the wiring look better. Still have a few wires from the wings to come into the back of the panel. Almost time to take it to the hangar and install the wings. Moving around and setting up the displays too. Not sure thiis setup is what I want yet.
