More electrical. Finished the Harness Interface Connectors for the Rotax Engine Control. Will test them before making the wiring look better. Installed the VHF antenna anticipating using it, but found out I was missing a connector. Dynon is sending it tomorrow. Connected some of the intercom and other systems. Wired the power and ground for the main EFIS. WIred the coax cable for the antenna.
