Wired and installed the prop hub without torqing the bolts yet. I don't think I will have enough room to install the prop in my shop. Soldered the connections to the Dynon EMS from the fuel pressure sensor. Put the firewall wiring sleve in place without bolting it in yet. Glued the window shims in place and put the foam tape on and then replaced the windshield for hopefully the last time. Need to get some washers to finish the install.
