More electrical connections. I hooked up the heater fans and tested them out. I tested the Master switch to the Master Solenoid and it worked well. Several other connections. Sorted out the pinouts and wires for the Dynon engine module. Have to change two wires but the crappy plastic pin removal tool looked like I was chewing on it after trying to remove the pins. Ordered a metal one from Stein Air. Did some work on the butt ribs and the back where the window touches the aircraft. Need to remove it and hysol the pieces in place then I can permanently install it.
