Finally brought out the windshield with Ted;s help. It fit pretty well the first time, but it did need a few cuts and some sanding to make it fit perfect. Lots of drilling too. Took a while and I was covered with plastic shavings but it is almost completly done. I am moving on to painting while the weather is good. Then windshield will need a little sanding at the butt ribs to make it fit over the laker leading edge fiberglass I have on my wings. Wanted to cut it flush like the manual says, but the holes are too close to the edge. Have to improvise slightly. Thanks to Ted for coming over twice and Amanda coming out once. The windshield is a two person lift because it is very delicate until installed.
