Sanded the oil level access door to make it fit more flush and then riveted it into place. Installed the two camlocs in it and riveted them in as well. Looks good. Test fit the cowling after sanding and smoothing all the Superfil and it looks good. Started drilling and riveting the camlocks. I started on the hardest parts of the stainless steel and it took a while. Got most of them done, and the fiberglass to fiberglass camlocs should go a little faster. Almost ready to paint.
