Cut the radiator NACA scoop on the bottom of the cowling and epoxied it in place. Will cut the cowiling under it next week. Had to trim it several times before it fit right. Lots of taking on and off. Cut the oil level access door and started cutting the cowl bump holes for the fuel rails to clear the cowl. Trimmed the cowl bumps and the oil level door too. Lots of fiberglass cutting and sanding. More to come.
