Cut and installed the connectors from the transponder to the antenna. The transponder is the only one with a screw on connector on the end of the coax cable. Then I went to work getting the cowling to fit better. With the prop and spinner backplate I was able to get some better measuerments. It turns out it is slightly different than the standard one Kitfox uses as a guide. I thought I cut too much, but it turns out I didn't. Put the wires and slipring on for the adjustment motor located in the hub. The slipring goes through the hollow drive shaft in the reduction drive and is mounted on the back. Pretty small and neat. Had to come up with a way to get the prop bolts through the backplate and then set the pressure fit lugs. It worked after turning the shaft for everyone. I might have to cut the bolts if I need to get them out though. Not easy.
