Ran a wire from the master solenoid to the fuse box that I have installed under the panel on the left side. It will be tucked up under and out of the way but will be able to be tilted down if necessary. I should have access to the fuses without tilting it. Started marking the panel. I went with the switches in the middle for the most part. Finished the new routing of the coolant hoses farther away from the exhaust. Lots of planning today.
