Finally finished bending and flaring the fuel lines in the cockpit. Put hose pieces on them where they will get close or touch other things and will zip tie them in place later. Moved the wire harneses around and temporarily tied them up with twist ties. Still need the fire sleeve to finish the fuel hoses in the engine compartment, but got the rest of the line today. Hysoled the aluminum angle on the top back of the greenhouse and the angles that will guide the wires under the seats up to the panel. I drilled some holes in the back for zip ties, but the front is up off the bottom fabric so I don' t need to. Wired the trim switch and tested it wilth a 9v battery. It works fine on the low voltage it puts out. Was going to install the ECU but didn't have the double sided tape.
