Cut and bent the fuel return line to the check valve under the center console. Crimped the wire ends on the fuse box to engine ground wire. Got bigger bolts from Ted to install the fuel filter, bypass valve, and manifold assembly on the firewall. Need more fuel hose and firesleeve to finish the fuel system, but cut the second to last fuel hose up front. Cut two pieces of aluminum angle to guide the wires and lines from the back to under the console.(pic)
