Worked on the fuel hoses in the engine compartment. Finished the bending and connecting of the fuel filter and bypass assembly. Put the final terminal connection on the power line to the starter from the starter solenoid. Fitted the seat and made sure the fuel supply line would clear it by enough, and planned the fuel return line out. Not a very productive day. Everything went slowly and not as well as it could have so I knocked off early. The second picture is between the seats lookin forward at the elevator and flap control rods.The rudder cables are not fully installed and are loose.
