Started cutting the acrylic bubble doors. Had Ted come over and help me hold them in position so I could mark them and then cut with the dremmel reinforced cut off wheel. Lots of cutting and then evern more sanding. Went with the hand belt sander because everything else was too slow. Left a fair amount to sand so I didn't mess up and take too much off. Made a real mess of the shop, but got a pretty good fit. Drilled the holes in the door frame too, and will fit them together tomorrow. The door frame was temporarily hot glued in place with popsicle sticks keeping the spacing.
