Prepped and hysoled the door frame and the tail access aluminum mounting angles. Had to drill the tail access angles first and then rivet them when hysoled. The doors had few rivets too. Cut and fit the pilots door in the afternoon. Measured the side pocket for the cargo area so I can finish it tomorrow. Fit the rudder after the fairing were dry from yesterday, and found a little too much gap. Will fix it tomorrow too.
