Hysoled the rudder and vertical stabilizer aerodynamic pieces on. Used quite a few clamps for the vert. stab. The rudder went on nicely. Hysoled the wingtip strobe standoffs too. Cut and drilled the tail access cover angles. Sewed the first side pocket together for headset storage next to the baggage compartment. Should get the headset jacks next week to add to the pocket. Designing the baggage compartment has taken a lot of time. I am not the fastest person on a sewing machine either but it is turning out very nicely. Hysoled some balsa wood onto the rudder bottom to give it shape and attachment area for the covering. Using balsa makes it feel much more like a model airplane.
