Drilled and deburred the rudder pedal to fuselage mounts. Filed out the inside of the pedal tubes so the bearings rotate freely and then greased and installed the four pedals. Mounted the assembly to the airframe and torqued the nuts holding it in place. Installed the adjustable pedal pulleys and fabricated cable retainer straps to keep the cable from jumping the pulley groves.
