Worked on the control bearing again, making a brace for the top, which did not prevent binding. The bolts are too close to the center and cause binding when tightened. Ordered new ones. Put two coats of polyurethane on the bottom of the floor boards. Drilled a few holes in the adustable rudder pedal detents.
