Drilled the holes in the floor boards for mounting screws. Worked on the flight control cross tube bushing agine and finally found the cause of the binding. Finally found the cause and will fix it next week with a metal top cap. Wasted a lot of time on that problem. Mounted the flap detent bracket adn deburred. Drilling through the hardened steel took a lot of time.
