ROBERT'S WEB SITE
Date:  11-5-2017
Number of Hours:  3.00
Brief Description:  Flight controls, floor boards
Removed the flight control cross tube and smoothed out the bearings. Had to cut off a nut that was stripped and wouldn't come out. When replaced the controls were much smoother. Fit the floor boards by sanding down the areas contacting the fuselage. Clamped them in place for drilling. Torqued the wheel halves to proper torque and filled the tires with about 10psi.
