Fitted rib reinforcement brackets and drilled through rib and second half of bracket. Removed and deburred, and prepped. Hysoled and riveted to ribs 1,3, 5, 7, 9 and then the other wing in correponding locations. Prepped the flaperon hinge brackets and then clamped in place and rigged the flaperons. Installed all hinges with clecos. Removed for permanent install after covering the wings. Lots of drilling today.
