Brief Description: Last false ribs, leading edge forms
Cut two new false ribs for the bottom of the tank out of plywood since I used three in the wing bay that has the strut attachment instead of two. Cut the trailing edge piece to fit the back of the ribs. Cut four spacers for the #1 rib and tank space. Prepped and bonded everything Used the template to position the 10 leading edge forms on the front of both wing spars at rib 1,3,5,7, and 10. Prepped and bonded them to the spar on both wings.
